I am still having problems sealing the right fuel tank access panel so I'm going to remove the fastener sealant and put some new fresh sealant. So I started the day by picking up some Proseal at Aircraft Spruce and Specialty Canada in Brantford. Then I proceeded to Stoney Creek Airport to work on the plane. I installed the cabin floor forward panels. Next I removed the baggage compartment side panels as I had learned that one of the MD-RA inspection items is for baggage compartment tie downs. I had purchased tie downs with my last order from Van's Aircraft and the tie down installation will be tomorrows project.
